Sorry John you're dead right!! Off to birch my self good and hard
I was thinking of
I hope you meant, an 80A 30mA RCD and a 63A 30mA RCD.i.e. dual RCD covering 2 split loads say 80mA and 63mA
Yes, I would formerly have said a 100mA "S" RCD on the incomer, but these days with an insulated CU and all circuits on 30mA RCDs or RCBOs, no need
Thank you JohnD you are right I made an error it is 30ma much easier when you say why you have quoted I will change the posts.down here we use 30mA RCDs for personal protection.
what make are your 50mA?
It could be, but in a TT system needs to be Double Poled.
If the circuit protective device is required to double as an isolator then that also needs to be DP in a TT system.
