I'm building a cavity wall conservatory which will be used as a kitchen. The walls will be constructed using red fletton bricks on the outside and thermal blocks inside. The height of the walls will be 1200mm. What is the minimum cavity width, and therefore the thickness of Celotex that would achieve the insulation required by regs? The structure will be under regs because I will be putting heating and drainage in too. Cheers
