Recently had shower tray replaced-plumber removed old tray and row of tiles above the tray. He found that the plaster board had been impregnated with water and replaced some of the board. A check under tray has shown that water is leaking behind the tiles, mastic seal to tray is ok. Have checked grouting and found loose grout and after scraping some out have discovered a void behind the tile joint; it seems the board may not have been completely joined. Any ideas as to best way to fill the void so I can grout on top without removing all the tiles?
Many thanks.
Many thanks.
