http://www.jmwlimited.co.uk/Tester_301C_Cable_Fault_Locator.html
Is this it?
No worries, I had a feeling I'd seen it somewhere as I used to use jmw a bit when I was in telecoms. The BT test stuff used to be rebadged (good quality) kit (probably still is I'm a long time out of BT) have a look at the davy lamps on ebay that have BT or GPO on them.
Actually seeing your post reminded me I've got a TDR amongst other test kit just in case I go back to telecoms...need to dig it out and have a play...
I`m looking for a cable tracer - any preference?
I'm V pleased with the mole so far, I've only had it a day and its helped me find a High resistance joint on an internal pair that i've been trying to find for ages (and looking in totally the wrong place)
They are a great bit of kit particularity if you're dealing with faults on long/awkward access runs, a 9083 and a tone tracer will get you through most faults but the TDR pinpoints the problem. I've used it on coax too works just as well.
Just looked them up on ebay![]()
It's not something I've used - reads as a multimeter/mega/TDR all in one I prefer my kit as separate entities so I've got some back up if one bit goes wrong. I'd hope it's a good bit of kit at the prices asked!!
I've got a bit of kit made by Ziad that was a buttphone/multimeter/keypad tester that I rarely used as I had to think too much about what settings to use anytime I went to use it!
Have you also used the BT Hawk?
They are available on eBay, but i'm not sure about buying one because presumably they are stolen.
