Hello everbody,
I seem to have caused a "discussion"!!
Just to confirm the requirement and attempted solution:-
The new "office/ shed/ room" is intended to be used occasionally, and only needs an extension of the main phone line. We have put in a cat5e cable to run from an ethernet port on the existing router to provide internet out there.
The line we have put in, and connected directly on to the BT socket, works fine - ie we get a usable phone line. The problem comes when, having plugged a new phone into the new socket, the internet through the original router does not work.
Would i be right in thinking from your replies that i need a "filtered" socket on the end of the new extention as this is causing some kind of reflected signal?
Is this covered by "master/ secondary" phone sockets? (I cant remember what we used!)
Thanks again!!
D
Thanks again!!
D
