thanks for that but there is not a stat connected to the boiler and i have changed the control panel but its just the same ?its a control fault not a boiler fault
As you say Sham, but also worth mention check for dripping tap. Or isolate cold feed under boiler, does it now come on for heating? Find drip or leak on hot water.
Well spotted old chum!!!As you say Sham, but also worth mention check for dripping tap. Or isolate cold feed under boiler, does it now come on for heating? Find drip or leak on hot water.
you would have d on the control panel if this was the problem
OP obviously knows better than you Ideal chapswere has anyone told you to change the three parts you have changed???
