i've looked at the pcb and it seems okay and fits okay, anyone any other suggestions please? Not that the heating is needed at the moment but ive no hot water now!
Debi
Debi
Wow ! That was hard work getting you to check those jumpers!
Still we persevered and you are all back to normal at no cost!
Now I had better go out and do a boiler repair otherwise I will not be able to afford dinner.
Tony
Hello, Just to be clear. If you have replaced an old PCB with the new Orange one from Ideal, you will need to take out the old pins (Blcak plastic covers that sit in the top right hand corner of the old PCB) Take these pins out 1 by 1 and fit in the exact position on the Orange PCB box) These pins tell the PCB that it's OK to fire.
You need to do this to remove the H5 fault. Turn off all power, and start the above proceedure. Re-power, and you should have a burner light and a C .
