There are products, like Kingspan K18, that can insulate the inside of a solid brick wall or roof space. My question is, given phenolic foam seems to have about the same K value (conductivity) as air, can I not use trapped air instead of foam?
This is a DIY site and we want to save money. Sometimes we choose cheaper materials at the expense of more labour. Materials don't get much cheaper than air.
I was thinking of multiple layers of polythene separated by 25 mm battens. If the air gaps are blocked at the top and sides but left open to the cold side at the bottom, the air won't move but any vapour from small imperfections can escape before it condenses. The inner surface could be foil backed plasterboard attached with screws long enough to go through several battens. Obviously the air gaps must all be sealed from the warm room and only open to the cold side. The air gap on the cold side should probably be left open at the top as well as the bottom to allow penetrating damp in the bricks to dry.
