Our living room has approx 17' span, don't know what size the joists are but the floor does sag, or at least it did - it was levelled with shims in order to lay a laminate floor a couple of years ago. It's level now but there is a bounce when you walk across the floor.
My question is, can I get rid of the bounce by supporting the underneath with a cross beam - ie running a cross beam along the ceiling of the room beneath our living room. The span of this beam would be 20' - assuming I get a steel beam, what dimension would be required in order to provide a firmer feel to the floor above?
thanks
J
thanks
J
