Plug Maker
12 Feb 2010
Norfolk
I'm currently building a deck out of the standard softwood decking boards you can get anywhere.
1/. When screwing nails into the deck boards, should I drill a pilot hole first?
2/. Can you use a plug maker for the fascia boards. I am using a deck board as a fascia, I have seen joiners use plug makers when they fit skirting boards to hide the screw heads?
Thank you.
(i'm a diyer, not a pro)
1. i did..... just feels safer, and if you get one of those switchable drill/driver bits, it's easy. But I suspect that with the quality of most deck boards you won't have to, unless you're close to the edge. But give it a go, if you start splitting timber every other fixing, pilot holes it is.
2. not sure i understand question 2... why would you want a neat and tidy finish on a fascia that (usually) will be well out of sight...?
As it's a facia and as such more cosmetic than structural you could always nail it with ovals or lostheads , punch and fill. But if you really do want to screw it then there's no problem using a plug cutter to produce plugs out of an offcut or the back of the facia.
st?
Is it me or the OP who is a bit strange ? Or are we talking about somrthing a little bit unusual ?
:lol: :lol:
Well, I'm sure we've all nailed a few screws in our time, so why not try it the other way round. :wink:
st?
good spot.. :oops: i just assumed the OP meant they were using screws, and should they pilot hole it first?
I did that on purpose to see if you were paying attention :oops:
No, I meant screwing screws - not screwing nails.
