Hi
Ive got a problem with a Vaillant Turbomax plus 824e. The pressure from the hot tap is weak and the water temp doesnt go above 56 degrees.
The hot water heat exchanger was replaced 3 weeks ago by a friend of mine and the customer said when it was first fitted everything was all good for about a week.
Could there be a blockage in the new heat exchanger?
The flow pipe in the d/h heat exchanger is hot but the return pipe out of the exchanger isnt.
