- Joined
- 19 Jan 2008
- Messages
- 2,373
- Reaction score
- 431
- Country
Hi all I got my nipper a 1989 1275cc mini metro, and it has been going really well but recently we have had problems with it cutting out and traced it down to the ignition .(wires on other side of the ignition barrel).I got another switch from flea-bay and put it on today and it started and took it for a run and was fine. But every now and again the motor would "die," and after a couple of turns of the key it was ok again, then when you were going along it would do it again.I found that if it was driven with hardly any pressure on the throttle and the revs kept low this never happened (low revs thru the gears)but as soon as you put your foot down and built the revs up the motor would cut out. But a couple of turns of the key and it was away again.!!! Now my nipper is only a learner and never uses the motor unless me and the wife go out with him but he will sit in it and rev it and the times he has run out of petrol by just doing that is loads. So could there have been any s##t sucked up into the pump or carb and maybe blocking the main jet? Will appreciate your comments.Thanks...Must add this motor was owned by a woman who had it from new and it has only done 52K miles and the engine is as sweet as a nut....
