Hello. Newbie here, be kind! I recently retired so have more time but less money to spend on DIY. Any hoo, my Vortex Riello boiler has functioned great for 5 yrs until just before Xmas. To cut a story short the filters (including the pump) were blocked with a red substance which turned out to be fungus. The tank is steel and 30 yrs old. Filters cleaned, new pump fitted, runs for a month then stops with the motor blocked, lockout. Press reset, vicious sounding BUZZ then lockout. Filters again blocked with fungus, which I now know should have been dealt with a fungicide. I stripped the pump down, cleaned it, new nozzle, reassembled it to the motor and using a bottle of kero, not the grotty tank supply, (the tank is being treated with biocide) it fired OK. Great thinks I, sorted without another new pump. No, 2 hours later lockout and the motor blocked. Strip down again, cleaned and again it runs for 4 hours then I turn it off for the night. Come to manually turn on the heating and the motor is blocked again. I guess if I clean the pump it'll run again. Are these pumps fully recoverable after being either run dry or blocked with whatever? Sorry it's a long tale......
