Hi
I changed a shower pump as the old one gave in. I turned off the gate valve at the hot water cylinder and the gate valve at the cold water tank in the loft for safety. I can't remember how much of a turn the gate valve for the cold tank took to close. The hot water was multiple turns - which I think is normal? Shower pump replaced - gate valve at hot cylinder was multiple turns back on. Gate valve in the loft is only a quarter turn back open - doesn't seem right? Pressure from the shower now fades after running a few seconds and (with pump on) and water is pretty non existent with pump off (previously was working ok but not with usual pressure naturally with the broken pump.)
My questions really are - am I likely to be right in terms of the gate valve is bust? Can I force it open somehow or is it a replacement job?
Also - hitting some problems trying to install the pump I thought I'd change the existing pipe connectors. Using the valve on the connector I tried to drain the hot water feed from the tank - expecting minimal water from gate valve (supposedly shut off) and the shower connector - ended up with a massive bucket of water. Now reading that gate valves are useless. I'm assuming this valve was bust also and probably needs replacing too? Is the assumed fault valve here likely to be causing a pressure problem - even though it's bust open and not closed like the cold one? I guess what I don't know is how much bust open - fully or partially closed!
Sorry - long question and maybe stating some obvious points but trying to figure things out with no real plumbing background.....
Many thanks for any help you can provide.
