Hi all
I had cleaned up the boiler wiring and installed a honeywell wiring centre to replace a messily wired 10way junction box
And as it is all clearly labelled it made life easier for myself when i bought a cheap drayton mistat wireless thermostat. just had to wire 1 and 3 between the 2
Ive finally gone for the big upgrade and invested in the honeywell evohome
Im a bit lost on wiring it in as the labelling on the bdr91 doesn't match to the wiring centre as other than the live neutral its A and B
If i wire as a room stat which was my first idea because I'm waiting for the hot water kit to arrive (another week) so still need my current programmer for turning on hot water , would A go to 1 and B to 3 on the wiring centre ?
And should i be wiring the bdr91 into the programmer section once i no longer require the old programer ?
Don't really want to change back to a 10way junction box but as all the wiring guides show it that way ill do that if its a issue
Lastly how would you normally power the bdr91 for the live and neutral ,through a separate 3map isolator ?
Want to do it right and this seems the best place to ask
Many thanks
Leigh
Many thanks
Leigh
