Hi all
I am in the process of fitting the Grohe rainshower system.
With reference to the "S" unions supplied on the kit I understand that the 22mm end of this goes into the shower valve unit but cant see how you can attach a 15mm pipe with olive and compression nut to the 15mm end as it will not go into the fitting like a normal compression set up so I've gone and got two female compression elbows.
What I need advice on it how to effectively water seal where the 15mm end of the "S" coupling fits into the female elbow? Would this be plumbers mate, PTFE tape a rubber washer? or is there a much better fitting to use?
Thanks in advance for any help
