K
kai
Much Class 2 lighting these days (Not UK made) is just the manufacturer deciding not to bother with an earth connection.
That may well be true at the bad and/or illegal end of the market - but if you're talking about things which actually need to be earthed, then they clearly aren't actually Class II - regardless of whatever words and symbols the manufacturer may use.Much Class 2 lighting these days (Not UK made) is just the manufacturer deciding not to bother with an earth connection.
I didn't say it would do no harm; I said it would be no more dangerous than class 1 items but it would be less safe than unearthed isolated metal parts.I'm not sure. As I've said, apart from the general desirability of reducing the amount of exposed earth metal in a house, an item being Class II means that it dos not need earthing, but that earthing would 'do no harm' - so "must not earth" seems totally inappropriate.Have I answered that already?Does not the definition/ specification simply mean that it is not necessary (but would no harm) to earth its exposed conductive parts in order to achieve the required degree of protection against the risk of electric shock?
As I surely don't need to tell you, I agree with all that. The question is whether it is ('normally') ever appropriate for the manufacturer of a (true) Class II item to instruct that it "must not be earthed" - as you say, if their exposed metal parts are earthed they don't become any more dangerous than pipework etc.I didn't say it would do no harm; I said it would be no more dangerous than class 1 items but it would be less safe than unearthed isolated metal parts. ... That is the same as earthed baths or pipes when this earthing is not required. They are no more dangerous than bonded extraneous baths and pipes but they are less safe than if they were not earthed
That might possibly be an 'exception that proves the rule' (i.e. not a 'normally' situation, per above comment). However, having said that, what's necessarily wrong with PELV?As I have said before, there are class 2 ELV light fittings where the metalwork is one of the 12V conductors. These items should/must not be earthed.
For another example earthing the braid on a TV coax may seem a good idea until one considered this may encourage a lighting strike on the aerial and cause untold damage as a result.
Aerials should be earthed. It does not encourage lightning strikes, it reduces the likelihood by discharging the ionised air. That is how lightning conductors work.
Ok. So it is just down to semantics.As I surely don't need to tell you, I agree with all that. The question is whether it is ('normally') ever appropriate for the manufacturer of a (true) Class II item to instruct that it "must not be earthed" - as you say, if their exposed metal parts are earthed they don't become any more dangerous than pipework etc.
What I am saying manufacturers are in a position to do a risk assessment having loads of data to help them. An electrician has limited data and so in the main countermanding the manufacturers instructions has to be deemed wrong.Ok. So it is just down to semantics.As I surely don't need to tell you, I agree with all that. The question is whether it is ('normally') ever appropriate for the manufacturer of a (true) Class II item to instruct that it "must not be earthed" - as you say, if their exposed metal parts are earthed they don't become any more dangerous than pipework etc.
If you think an isolated bath should not be earthed, would it not be acceptable to say that it must not be earthed.
I don't think so - and nor would I necessarily call that 'just semantics'. To say that "I think that an isolated bath should not be earthed" is perhaps over-stating the case and, in any event, would only be a personal view/opinion of mine. Even though I do have my own view (the one you suggest), I recognise that there are 'pros and cons' and that there are some people (even some in this forum) who believe that, on balance, it is better that the bath be earthed. Under those circumstances, I would/should not be the one, and I doubt that anyone should be the one, to tell the whole world that they must not earth it. ... and, of course, a similar argument would probably apply tp (true) Class II items which have exposed-c-ps.Ok. So it is just down to semantics. If you think an isolated bath should not be earthed, would it not be acceptable to say that it must not be earthed.As I surely don't need to tell you, I agree with all that. The question is whether it is ('normally') ever appropriate for the manufacturer of a (true) Class II item to instruct that it "must not be earthed" - as you say, if their exposed metal parts are earthed they don't become any more dangerous than pipework etc.
Earthing an antenna will make naff all difference to whether it gets struck - it's going to be "almost earthed" simply because it's connected to various bits of equipment which are at least lightly coupled to the mains - at most standing at around 120V AC if none of the equipment is earthed. In the grand scale of a lightning strike, that's nothing.Lighting conductors are at least 25mm² often far larger there is no way a coax braid will take the currents involved so no way should it ever be earthed. One can use braid breakers to stop the DC connection and then earth after the braid break but NEVER earth an aerial with less than 25mm².
The mistake is yours. If the aerial is struck then that's going through the house regardless. As above, earthing the aerial may actually avoid the strike occurring in the first place, and it may well avoid expensive damage (and personal injury) due to nearby storms.But the fact that some one actually thinks you should earth an aerial shows how easy it is to make mistakes. "winston1" clearly does not see the danger in routing 5 billion joules through the house.
I don't think we are actually disagreeing (see below).I don't think that we are going to agree, ...
I answered that in my response to you well over a page ago:... so - under what circumstances or for what reason would you earth an exposed-c-p of a genuine, properly installed class 2 appliance?
In practice, I can think of only two situations in which one would normally contemplate earthing exposed metal parts of a "Class II" item ... Firstly, as in bernard's hypothetical example, if the earthing was going to happen 'by accident', and one didn't see the point in expending effort to avoid it getting earthed. Secondly(per recent threads) if one didn't relieve [should have been 'really'] believe/trust the fact that the item was satisfactorily 'Class II' (although one really ought to simply 'reject' such a product and get a proper Class II replacement).
See above. However, even though they are my personal views, I certainly am not going to jump up and criticise anyone who, for whatever reason (even if I consider it 'irrational'), feels the desire to earth exposed-c-ps of (genuinely) Class II items. As I said, AFAICS the only arguable 'downside' is that it will fractionally increase the amount of earthed metal around the house for one to touch. However, that would be virtually insignificant in a house full of pipework, radiators etc. which are connected to earth - so I couldn't say that the fractional addition to the amount of earthed metal resulted in any significant increase in risk (particularly if one was unnecessarily earthing something on the ceilingHave you earthed all of your class 2 tools (or any spoons) ?
There you go -I told you we weren't disagreeing.Ah, sorry, I couldn't have absorbed your previous answer. ... I totally agree.![]()
