I would appreciate some advice regarding 3 way light switching. I have studied the wiki and understand the method shown, but I was wondering if an alternative was feasible.
My garage has 2 way switching at present, with a switch at each end, both close to a corner. I would like to add an intermediate switch halfway down the length of the garage, on the opposite wall. The routing of the current 3 core + Earth cable would mean that simply rearranging the cable to connect one existing switch to the new intermediate, then using a new length of cable from the intermediate to the other existing switch would be problematic, and I would therefore prefer to use two (fully exposed) junction boxes, splitting the existing cable.
I see from the wiki that the cable linking the Common terminal of the 2 way switches (the yellow cable in my case) is joined in the intermediate switch, bypassing the terminals. As I would be running two new lengths of cable across the garage from adjacent junction boxes, I was wondering if I would be able to merely run a short length of cable between the junction boxes to the relevant (yellow cable) terminals, then use 2 core + earth for the remainder of the JB to intermediate switch wiring? And if so, would I be OK in snipping back the black cable and using the red and earth only in the cable joining the two JBs? Or should I use a choc block/Wago to terminate? And am I OK to use non-harmonized colour 1mm cable, which I already have?
Hope I have explained this properly, and I would be more than happy to be told there is a better way!
