Hi all,
Whilst renovating our bungalow we will be fitting additional & relocating current sockets and switches.
The lighting wiring runs throughout the loft space and the socket wiring runs below the suspended timber floor.
Can I run conduit to the back boxes with the intention to upgrade and run additional wiring at a later date? (To spread the expense)
What regulations must I consider?
Examples are:
- conduit down to light switches, between a studded wall (with insulation fitted both in the loft and between the stud wall)
- conduit fitted upwards to plug sockets, through 150mm sheeps wool insulation into either a studded wall or "dot & dab" dry lining on external walls.
My limited experience considers issues with fire protection and drafts. But maybe the use of expanding foam or gaskets would help?
Examples are:
