My Dad said:If you two don't pack it in, I'm going to bang your heads together
RF Lighting said:My Dad said:If you two don't pack it in, I'm going to bang your heads together
Pensdown said:RF Lighting said:My Dad said:If you two don't pack it in, I'm going to bang your heads together
Spoil sport....I was enjoying that![]()
ricicle said:joe-90 said:The category that sees the entire electrical trade wiring up houses knowing full well that the cables will be covered by insulation. If it's wrong - why are you doing it?
I don't and I wouldn't
davy_owen_88 said:joe-90 said:The category that sees the entire electrical trade wiring up houses knowing full well that the cables will be covered by insulation. If it's wrong - why are you doing it?
It's beyond our control what people do after the work is finished... When they are clipped to the top of a joist we are doing as much as reasonably possible to reduce the chance of them being covered in insulation - out of curiosity where do you suggest we put the cables?
JohnD said:However...
Cables, especially shower or immersion cables should not be buried in insulation. Lighting cables are usually so lightly loaded that it does not matter.
Cables should not be put next to hot pipes as it shortens the life of the PVC insulation.
Go down any high street and you will see cars speeding over zebra crossings and past schools; but that doesn't make it acceptable.
joe-90 said:In that case you aren't a working spark.
ricicle said:joe-90 said:In that case you aren't a working spark.
What is your definition of a working spark?
joe-90 said:ricicle said:joe-90 said:In that case you aren't a working spark.
One that works in the real world.
