Thanks for that I have the kewcheck one. After changing any socket I use it to confirm the socket is wired correctly.
I did this with the above socket and it gave a continuous sound with all three lights on the front stating it's wired correctly. I have just wired it the correct way using the correct colours to the relevant terminals and it says that L and N were reverse. I corrected this so it shows as the picture and it states it's now Ok. I have also used the Fluke VoltAlert which confirms and so does my multimeter that the live is indeed the blue set of cables.
I have also moved the 'earth' cable down to where it should be and when this is placed there it trips out so this confirms that all the cables are correct however are the wrong colour.
James
James
