Hikvision IP camera
  • Thread starter Thread starter dya
  • Start date Start date
dya
2 Jan 2017
Romania
Hallo you guys
I whant to install an IP camera, hikvision DS-2CD2020f-i, but I don”t whant to buy an NVR for it.
I will connect the camera on my internet switch, and browse the image on my pc.
It is possible to live view the camera on my android smartphone just by installing iVMS4500 without the NVR?
The storage will be made on the HDD of my pc.
Thank you
You can even watch all the event (videos and pictures) captured by the camera if you install an SD card inside it, just with the apps. No NVR needed.
storage of images needs to be thought of very carefully, I wouldn't rely on sdcards and pc recording although its possible.
1. sd card is a limited size
2. pc harddrives are not designed for continuous use
ok
thanks for your hints
for the moment I just whant to see the camera over internet on my cell phone without buying an nvr
Can't remember the ins and outs but #2, secureiam, when hard drives of a sensible size came along, suitable for dya's use (many) years ago though, I was always supplied with 'special' hard drives, NOT PC hard drives, but ones especially for being constantly re-written, and other bits(?). The PC HDs never stood up to that sort of hard use. :sneaky:huh
Hello
I use a Seagate video Hdd 3.5”, 64Mb buffer / 7200 rpm. It works fine since 2014
I am an IT engineer and from my experience it is enough to enable the write disk cache on the hard disk... this way you avoid short burst of writing.
My hdd (normal el cheapo WD elements on usb2) has been in use since 2012 with the two external ip camera (pir activated)
