Replacing skirting boards
30 Aug 2017
I am replacing skirting boards in my bedroom and have come across a bit of a challenge.
When i've removed the old boards, i have exposed a hole behind one which appears to be the ceiling void of the bay window on the ground floor (bay on ground floor, flat wall on first).
My question is, how can I now fix my skirting board. I could glue along the top edge of the board and stick it to the wall above the hole but my concern is that if the bottom gets knocked it will just fold under.
Alternatively I can try to nail through the skirting and into the floor boards but i am concerned that this will just push the board back into the gap also.
The original board was taller than what I am putting in and was nailed to the floor boards.
Is the ceiling void "inside" or "outside" in terms of insulation? Just check you're not giving yourself an extra air brick there.
Personally assuming it's plasterboard wall if it's big just fix a batten behind and a small strip of plasterboard if necessary. Then you can pack out and fix your board. I've tried screws, no more nails, and fixing foam for skirting and they all seem to work OK once it's on. But the no more nails was very wasteful.
Thanks for replying John,
I'm not entirely sure to be honest. The void looks like it is the gap between the felt on top of the bay and the ceiling construction below, so i would hazard a guess that it is external, and possibly that there is no insulation.
I'm a bit lost by what you mean about air bricks - I know what one is, but not what giving myself an extra one means...
It's a brick wall that's been plastered and skimmed, and i can't get to the other side to fix a baton under for fixing onto.
Can you insert a chunk of wood into the hole?
Either a bit that is close to size or using wedges to get a tight fit.
You can grip fill the skirting as well
That's looking like my best option - either that or screw a baton down to the skirtings and fix to that but all run the risk of being pushed too far back into the void...
I wanted to avoid physically fixing anything to the floorboards so i can take them up if needs be.
So if it's a brick wall, does that mean it's built onto the floorboards?
A photo would clear a lot up for us.
