Hi I'm wanting to build some shelves using scaffold boards. The wall has a boxed in plumbing running down the centre, so originally I was going to put shelves either side of it. But now I'm thinking of using one long board with a bit cut out for where the box is. Would the be any problems in having a shelf that was nearly three metres long. I would use four brackets a bit like if was putting up two shelves.
Also any advice on how to cut the bit out for the box. The board woild be about 22cm deep and the box is about 19cm deep and about 30cm wide. Thank you
