Hi Guys
Just need to find out from you experts if I can lay a laminate flooring over oak wood flooring in my lounge.
The problem I have is that large gaps began appearing in my oak wood floor which is laid over concrete. Invited couple of builders to give me a quote. One of them suggested laminate over solid wood will be OK and the other says never to install one flooring over another, instead either to remove and re-fix the current flooring or for a brand new flooring. The builder reckons the previous guy who laid wood flooring did not glue it onto the floor and so they are moving.
But taking off flooring will incur extra expense so I was wondering if I can get laminate installed over solid wood.
What do you guys suggest?. Appreciate your help.
Regards
Regards
