I've messed up slightly. My kitchen ceiling is 2110 high and the unit with the oven and microwave in is 2110. This leave just 10mm between the top og the door and the ceiling.
With the low ceiling I've installed down-lighters which are fine and the doors clear them. I've also put in a cable for a heat detector and intend to link it to smoke detectors in the rest of the flat.
The cupboard door will hit a surfaced mounted heat detector and I wonder if there is a recessed heat detector, mains voltage and interlinkable?
I've not found one but hope that someone reading this knows of such a unit.
thanks
John
thanks
John
