Remove the plug from the vacuum cleaner and hard wire the lead into an FCU, that will stop anyone plugging the vacuum cleaner into any 13 amp socket. Simples.......
No.so does the 900W 'limit' change your views at all? What appliances other than vacuum cleaners do you envisage people plugging in to sockets in a loft?
Perhaps we should have a whip around to buy one for winston, so that he can leave it in his loft to deter anyone from plugging in any other vacuum cleaner up there?
Seems a stupid idea.Remove the plug from the vacuum cleaner and hard wire the lead into an FCU, that will stop anyone plugging the vacuum cleaner into any 13 amp socket. Simples.......
They'll probably have an extension lead with a MIG welder and an engine hoist plugged in as well.Scenerio workman doing job outside plug in extension lead to a kettle to make a brew.
FCSs are not used or needed on lighting circuits as they are adequately protected and even a 3a fuse offers no discrimination against a 6a MCB.Great idea. FCUs are allowed on lighting circuits, too!
So, why do you not contact them and put them straight. Why bother the rest of us with it?Fan manufacturers instructions are wrong
What does one do when fitting such a fan in one of the many countries where FCUs are not available nor complient?
What happens when a fan goes short circuit and the 16 amp MCB permits more than 4kW of energy to be dissapated in the fan.....?
