If the total depth is 75mm, what should the depth of the hardcore? and the cement? be...
The 75mm is the concrete depth -although as I said maybe you could go down to 50mm, but the thinner you go the more risk of it cracking due to ground movement.
you need really to dig out the soft top soil and replace with hardcore.
Its a bit tricky to give advice on depths as its all dependant on ground conditions. If there are lots of trees around then roots might cause a lot of movement, especially in clay soil. In stable ground bearing soil like sand, mudstone etc theres less risk of movement.
Do you actually need concrete? -could you just put down type 1 hardcore use a whacker plate, then blind off with sharp sand and lightly whacker that.
