D
Deleted member 262063
Hi All,
I've just signed up and took a look over the forums but couldn't find my specific answer.
I have a lean to that is attached to our garage and the garage is underneath our space room. I can access the garage directly from the house and the lean to directly from the garage. Essentially they are all attached.
The lean to is a single skin water tight building that has a garage door and a back door (as well as a side door into the garage/house) and also has electricity.
I would like to insulate the lean to as well as add a partition wall to have two separate sections of the lean to. However I do not want to change the use of the lean to, it will still be a storage location for tools, garden bits etc..
for insulation - 70mm PIR Celotex on the floor over a DPM and then 22mm tongue and groove chipboard. then PIR insulation boards on the walls and ceiling.
My question is, do I need submit a building regs application to insulate and add in a partition or would the fact I am not changing the use mean I can do it without having to get sign off from the building regulators.
