I've set my bath in position and carefully measured and planned through the many scenarios before setting the datum line just above the bath. It means that I will have a 3/4 tile going on above the bath once this batten is removed.
I've set this datum line across all 4 walls of the bathroom to ensure that all the tile lines are straight. This has worked out very well so far.
Q. when I remove this datum line, there are 2-3 rows of tiles required in other parts of the bath (with the exception of the bath area). How should this be done?
Do I need to set another datum line and how do I keep tiles level and ensure that they finish exactly where the other tiles started.
I hope that makes sense.
