We had our flat rewired a couple of years ago, and we had the electrician install a connection to allow us to fit outdoor lighting on our third floor terrace at a later date (and they left us some SWA cable, grey/black/brown).
They fitted a light switch that runs to a backbox on the internal/room side of the external wall to the terrace, inside the box is a simple electrical connector where the internal wiring (blue/brown/earth) ends and a blank face plate covering the box.
We now have finally got around around to wanting to install the outdoors lights, and wondering what to do. I never really thought about it until now, and just took the cable from the electrician in thanks at the time.
We have purchased two external lights that are mains powered. The lights are dimmable (as is the switch in the room):
https://www.amazon.co.uk/Philips-myGarden-Bustan-Pedestal-Bulb/dp/B06WWHXHK7/
Is it necessary to run SWA cable to these, and if so how do I terminate SWA into a standard backbox? and ditto into the light fitting?
The install manual for the lights doesn't really give much information - it looks like the cable simply goes up through the base of the fitting, and the fitting is then sealed in itself once assembled.
The cable runs will be about 2m and 4m and not buried in soil, they will be loose laid under decking on the terrace.
Any help much appreciated.
