There are so many similar items in these forums, with regards to battery problems, that, as a retired battery laboratory testing technician, I thought I should give some guidance on car batteries.
A 12 Volt battery on a car, is 12 Volts ad infinitum (Unless completely shot!). This will be 12 Volts, until such time as a load is applied (turn on the lights etc) What happens when a load is applied, will indicate whether it is fully charged or flat. If it falls to less than 10.5 volts on load, you are in trouble. If it's less than 10.5 volts OFF load, it's scrap. (About a 2% recovery rate, but at MUCH reduced AH capacity.)
A good battery, is charged at 14.7 volts, and this will fall to around 13 volts when the charger is removed.
If the battery is allowed to discharge to less than 10.5 volts, it will decay rapidly, and needs charging IMMEDIATELY. If left at 10.5 volts or less for any time, you will probably NEVER recover the battery, even if recharged.
It MAY come back to 12 volts, but half the plates will probably be shorted out by paste falling off the plates, and shorting themselves out in the bottom of the battery. SOME plates may not get shorted out, which will still give the battery 12 volts when charged, but the Ampere hour capacity of the battery will be massively reduced. 8 positive plates, and 7 negative plates per cell, may be reduced to ONE of each still working. It will still give 12 volts after recharge, but the Ah capacity of the battery, could have gone from 40Ah to 5Ah for instance. May not even start the car!
Never judge a car battery by its voltage OFF LOAD!
Addendum:
If off load voltage of the battery is less than 10.5 volts, then chances are, that one cell already has a short (positive to negative plate), and charging it, will be like putting air into a punctured tyre.
Addendum:
