Paving above ACO channel?
5 Dec 2012
Do need to bed the paving slab slightly above ACO channel or can I butt I lt up to it level with edge? (Mortar will be buttered up to the edge of ACO as per @noseall advice)
I’m hoping the latter because I’ve installed the ado channel level with the top of the edging (which will be where the patio will be level/flush with also)
Cheers
Level is fine, as the slabs will be slightly angled towards the drain, anyway....
Cheers
Miniscule ponding occurs with any textured/riven slabs, unless they are smooth....
...even then, the water does not drain off instantly.
As said, flush is ok.
