I have a concrete base and want to build my shed on this. I plan to use 18mm OSB as the floor. I was advised to build a timber frame under the OSB board to give it strength and rigidity. Additionally, it was invested that this frame is raised from the concrete base so that it isn’t sat in water puddles. I was wondering if I could purchase some cheap
Paving slabs and the. Cut this in a few pieces (using my grinder) and then spread across the base of my floor frame?
Also, if any levelling is required, can I use some plastic spacers under the slabs or should I be using something else?
Thanks in advance.
Thanks in advance.
