What inline extractor is best
4 Jul 2011
Newcastle upon Tyne
Hi everyone, I am getting house rewire done and going to get extractor fitted in loft whist getting done as currently none, I have a average 3 bedroom home and wanting a inlin3 extractor that will go in the loft then out of the soffit under roof, what is the best brands and what will be best size to get most moisture out , I know most have a m³ a hour etc ?
Is there a minimum I should aim for.
Any help appreciated
Thanks dean
The key is to have a sensible gap under the door - 6 mm minimum so the fan can draw dry air from within the house to ensure the moist air is extracted AND have the timer / over run set to 10 minutes minimum.
Then you need the vent pipe to be relatively short and the fan set higher than the pipe to the outside so any moisture runs out of the pipe and not back not the fan / bathroom vent
Something like the fan above is suitable
Is there a good reason for fitting an inline, rather than a direct, more efficient and effective - through the outside wall extractor?
If it is for a bathroom, and you have long steamy showers in the modern style, you need a throughput of about 240 cubic metres per hour.
(For background, the cheap 4-inch fans often fitted by builders are about 80 metres per hour, and are adequate for a small WC cubicle)
You also need a run-on timer to continue drying the room after you have left it. The timers are usually adjustable but 20 minutes is common.
Some people have an aversion to ventilation and will not switch on extractors. IMO the best control is a fan that comes on automatically with the light switch. Some people prefer a PIR movement detector, though this may not work if you are wallowing motionless in a bath. Humidity sensors I find do not start up quickly enough, and do not react to odours.
Next you need low noise. One of the reasons people object to ventilation is that some extractors are quite noisy. Compare the dB rating of models you are looking at. As you are planning a loft installation, you can mount it on a thick ply base, padded with carpet or other material and screwed to the roof timbers with rubber washers under to screw heads to deaden vibration. It need not be on the ceiling.
I find the Soler & Palau "Silent" range very good. They have a ball-bearing motor which should run quietly for many years, mounted on rubber bushes, and the build quality seems very good. They are also sold under the "Envirovent" brand name (same company) and price and availability sometimes vary.
Example
Or a bigger one.
Incidentally, rigid duct is very superior to convoluted hose. It is more durable and less prone to trapping water, dust and fluff. Apart from the short riser through the ceiling, you should slope it slightly so any condensation runs down the straight tube and drips outside. You can insulate it to reduce condensation.
You will need a gap under the door so that replacement air can enter the bathroom.
if you want maximum efficiency use rigid extract pipe -the flexy stuff is pretty rubbish really
and if you dont want condensation then insulate it
Where would I get condensation in the loft ? And what is best way to insulate the pipe .
I will make sure fan is higher and pipe slopes towards soffit I will also be getting triple pole isolator fitted outside bathroom.
I want one in loft for ease as currently none and don't want tiles off walls etc for wiring.
So I need a fan including vent for bathroom side and pipe, one that alsp includes a timer or do most of them ?
Any links would really help, I have seen on above but don't think includes the other accessories.
Some at work recommended xpelair aswel
Thanks so much for all the recommendations so far.
Dean
The loft is cold. If you blow warm steamy air through a pipe in a cold loft, condensation will form in the cold pipe..
On any cold surfaces in the loft - walls, roof timber, under side of roof. You don't want to be adding any extra moisture into a roof, it can and does do a great deal of expensive damage to the structure.
Absolutely any insulating material, wrapped around the pipe. Idea is to prevent, so far as possible, the moisture charged air condensing out, inside your pipe/duct.
Would rather have inline one rather than the one linked above to keep out of the room as you say, So basically I need a inline with decent flow. Mounted higher than the ducting , also wrap ducting In insulation to stop any condensation, my old loft used to be covered in water droplets on roof of loft but I certainly want this one dry. Any links to insulation would be great ?
I will also have timer on to stay on 15-20 mins after lights Go off
Also any nor recomendations for a powerful inline kit would be appreciated .
Thanks dean
