Hi everyone,
I'm hoping someone here can shed some light on a frustrating issue I'm having with my brand new Glow-Worm Compact LPG combi boiler. I had it installed in my small bungalow about two months ago, and for the first month, it worked like a charm. However, for the past month or so, I've been experiencing random pressure drops.
The error message on the boiler display indicates that the pressure is too low. When I check, it's often at zero. I've been manually refilling the system to bring the pressure back up, but the problem keeps recurring at seemingly random intervals throughout the day and night, even when the heating and hot water are not in use.
I had my original installer come back to inspect the system. He suspects a potential leak in the central heating loop. However, there are absolutely no visible signs of leaks anywhere in the house – no damp patches, dripping pipes, or anything like that. This makes me wonder if the leak theory is correct.
If it's not a leak, what else could be causing these random pressure drops? Could it be a faulty expansion vessel, pressure relief valve, or something else within the boiler itself?
At what point should I contact Glow-Worm directly? Is this something covered under warranty?
Any help or advice would be greatly appreciated. I'm at a loss as to what to do next!
Thanks in advance!
Thanks in advance!
