Hi
Ref grouted the whole bathroom last summer with Mapei fast setting mix yourself grout. I used the fast setting, as only have the one bathroom, and need to use it as soon as. It was warm weather and going off quick, so being a diy'er I was mixing small amounts as required, correctly measured out.
I shook the bag, weighed out, mixed with coreect Qty of water, and left for stated time, remixed and went at it. I applied with float, removed excess, waited a while, and sponge off, I didn't tool the finish, as I assume most don't nowadays, I just tided up with the sponge, which left a dry looking even finish. Come 6 months later, parts of it in the wet areas (shower and behind sink) looked like mush, not all but quite a bit.
I re grouted the poor areas again, and as I speak, a couple of bits look the same again. One thing I may have been a little guilty of, is the lack slaking time, as I was probably a bit anxious from the speed it was drying when I did it in the summer. Is this stuff generally good, any suggestions of good premixed small tubs too correct, what are your thoughts please as to what's going wrong, be it my process or not great product? I did also seal second time with aerosol sealer 3 coats, but hasn't looked to have done a lot. Thanks in advance
