it is very likely that your solid floor is carrying damp.
tape a piece of clear plastic tightly to it and see if moisture forms on the underside
although an 1880s house might not have had a dpc in the walls, moisture usually evaporates off the bricks provided they are uncovered. In your case there can be no evaporation from the inside surface, and the floor is probably adding more damp.
