Supply to shed!
10 Jun 2007
Cardiff
I'm wiring a brick shed and I've got 2.5mm SWA running into it then i'm going to connect it to a socket then to a light switch etc via a FCU.
One thought...
Is there anything wrong with the input to the shed going straight into the FCU(used as a light switch) and taking the socket supplies directly from the input of this FCU?
Basically its OK to do that but an important qualifying question question to start with:
How will you be connecting the supply at the house end?
What route does the cable take to get to the shed?
How long is it?
How/where have you glanded it at each end?
Do you know that this is notifiable?
That way would be three cables and an swa gland into a single box, nothing wrong with that, but there would be more room if you first went into a twin socket box.
You can still wire your switch spur for the light between any of the sockets or the end of the run.
