Air compressor in a humid cellar
28 Mar 2025
I'm looking to buy an air compressor for both general use and for my laser cutter. I'm sure I know what to do to operate and install it, but I'm just unsure how it will operate in my humid, cool cellar. I need dry air, especially with my laser. How effective would an air separator be running at 30PSI in such conditions? I'm wondering if it would either fill up in minutes or just not remove all of the water. If used for a long job it could be going for quite a while.
Nick
Is there a branch of Machine Mart near you?
Consider CAT 169, but the staff there could advise you better than me.....I have used this for paint spraying ages ago.
John
keep in mind compressors even " fairly silent " ones can be very very noisy
and iff your not a detached property may not be popular
John
Thanks. I had never heard of Machine Mart. There's one not that close to me, but I'm going close-by at the end of the week so I may pop by.
I was going for a "Silent" one as this is in my cellar and if it ran for an hour on a job it'd be annoying upstairs!
I have a compressor that sits in a “kennel” outside my garage with the airline coming into the garage where the separator sits and the supplying an airline reel.
How big a compressor?
I have a small one, so it has to run a lot. It’s very noisy (sealy 24 litre ) and when topping up you can hear it all over the house from a built in garage.
I’d build a kennel type shelter outside. Our massive one at work is in a different brick built space.
Damp air wise, can you bring in drier air from outside?
Also, we have laser cutters at work and have to have massive extracts as laser cutters put out toxic fumes.
I wouldn’t fancy breathing in fumes in a cellar.
Any extracts would need baffles to stop noise from the cellar annoying neighbours.
You could fit aa second tank? Filled from outside and then used to feed the cutter using air from a compressor outside with drier air? But be careful of fumes.
Thanks. Unfortunately I'm in a terrace and the cellar is at the front. I don't fancy building a small kennel in my front garden. I'm hoping to sell up in a couple of years to give me a better workshop in the future.
The one I'm thinking of getting is this one. I'm not sure if you can plug in an air feed into this one to take the air from outside, but that is a good idea. I do have some bigish, but quiet extraction fans (x3) ducted through a Perspex panel covering the open cellar window. Not ideal, but it works. I actually have an automatic air purifier upstairs to catch anything that escapes!
Getting water out of compressed air in a controlled manor is a pain in the arse. The main ways are refrigeration and desiccation media. The former requires eye wateringly expensive hardware and the latter eye wateringly expensive media. I have had fairly good results using a water trap made by snaking a piece of pipe up and down a wall and installing drain valves at the lowest points to allow water to be tapped off. I've used the air for some spray painting and it looks OK. There's also a reasonable amount of water in the traps, though I haven't measured how much makes it out the other end.
One thing I might also point out is that if the compressor is in a damp cellar that's a danger of it turning into a rusty compressor. Might be worth investing in a dehumidifier for the cellar.
Also, I seem to recall a friend of mine having fairly good success painting his cellar with some kind of sealing paint.
