Indeed
The toilet does not not need to refill in 30 seconds.
Fit full bore stoptaps and better again.My Megaflo cylinder has 22mm tappings. After increasing the pipework to and from it to 28mm, I saw a significant increase in flow rate.
A 9 litre toilet cistern will fill in 1.5 minutes with a 6 litre/min flow regulator. Dual flushes for pees use even less than 9 litres. There will be no problems regulating a toilet fill to 6 litres/min in a normal house.It can come in handy when you have a full house though.
You don't increase the flow, you limit the reduction. If you read what I originally wrote you will see I mentioned upstream and downstream.
If you have a significant restriction at the start of the run, once the flow is gone its gone. Upsizing something after the fact does not magically get the flow rate back up. It just maintains what is left.
For my part, all of the reading I've done on the subject says that reducing the pipework resistance anywhere in the run will result in increased flow.
Yep Dannyboy. The 35mm pipe will not make it better for sure. That is why I asked what the flow rate is at the boundary. If it is say 30 litre/min, large bore pipes from the boundary, under the ground and throughout the house will pretty well maintain that 4 bar and 30 litres/min.So, upgrading the pipe work downstream of a significant restriction will do nothing to improve the raw performance of a main. It will just limit any further drop in performance. If the OP has 10m of 20mm main coming in and that is restricting his flow down to say 25l/min, putting 32mm MDPE in afterthat will only service to maintain that 25l/min.
What you meant was it increases flow over putting in small bore pipes. It will not increase flow from the boundary. What to get from the boundary is what you get, which in most cases is fine. It will maintain the flow.Let me clarify that - I should have said increased flow at the outlet - ultimately,
I have ben quoted £2k by southern water to upgrade my water main from 20mm MDPE to 32mm.
