Ive used those on well supplies before but thought they were a bit noisy for inside the property, anyone tried this ;
http://www.twsuk.com/?p=mbchome
http://www.twsuk.com/?p=mbchome[/QUOTE]
I was assuming he had somewhere to put it. Even if its out the way or bo ed in in the loft, insulated and sound proofed.
There accumulators mate. Was talked about earlier in the topic. I assume it uses the pump to boost the working pressure to 2bar so the accumualtor then works? I may be wrong tho..... Never fitted on with a pump tbh Cant see =the point?
pump connects direct to the mains (???) and charges the accumulator to 3.5 bar, that then tops up the main where necessary as the pressure is dismal
not used one before but not enough pressure alone for an accumulator and takes up less room than a break tank and more siting options in this property
price is very comparable to a break tank and pump too!!
