Excuse the weird question, but I have to question what an architect is proposing.
I have had plans drawn up by him to convert a 1930's semi into two flats.
He has advised for the ground floor garden flat that Planning Permission for a 1 bed flat be sought, then once approved, you build as a two bed instead, except you call the second bedroom a study.
I think parking is the issue with a two bed flat - which the architect is trying to get around.
A 3mt ground floor extension will be added.
I think this would be OK if I were to rent out, but I wish to sell instead. I will retain the upper duplex flat.
Can someone advise, I will assume, once approved for a 1 bed - to then make internal alterations to add another room (a study - as the Architect wants to call it) one needs planning permission ?, in the case of a flat.
On a side note, if you use a Private Building Control company - I assume they submit final inspection certs to the local council for filing, are these documents linked/cross checked in any way with planning documents.
