Wago connectors have already been in use for over 50 years.Give them another 50 years of use
What would another 50 years prove?
It only takes 30 seconds on-line to confirm that what flameport says is literally true. The Wago company was founded in 1951, they obtained various patents for spring-loaded terminals in the 1950s and were probably producing products using that technology in large quantities by the 1970s. However, I don't think that means very much.Wago connectors have already been in use for over 50 years. What would another 50 years prove?Give them another 50 years of use and no problems reported and I might accept them capable of everything they claim.
In contrast, we have a lot more than 50 years experience of traditional screwed terminals being in long-term ervice, and the design of those have changed little over the decades.
Quite - and, as I wrote, each time a new variant of these things appears the 50 year (or whatever) "long-term in service experience" clock gets reset to zero. I very much doubt that any new-fangled connectors being installed will remain essentially unchanged for anything even remotely as long as traditional screwed connections - so, unlike the case with the latter, I doubt that we will ever have particularly long-term in-service experience of products currently being installed'!Yes the Wago (Hellerman Tyton was another too) as I know it was the push on, waggle and pull off originally and then the lever types and that certainly a few years back but not 50 years though.
I feel the same about lever wagos, for situations with solid strands I prefer the NON lever push in wagos.Personally I am not over enthusiastic on crimps or Wagos,
I am a fan of the Wago itself but am not quite easy of mind at the higher end.
Now that is just me , my peculiarity, and I accept that.
But - it might well prove a Tadd difficult to get my opinion then because I am approaching 70 years now, when I reach towards 120 years old I probably will not be too bothered about it.
I am more than happy to use them on lighting circuits and small power circuits though.
Crimps, well there are some well manufactured crimps and crimpers about so providing those are used rather than any cheap rubbish then ok as are Wagos.
Indeed their big brother crimps using hydraulic crimpers are used well by the big boys.
For what it's worth, there I definitely do differ from you.I feel the same about lever wagos, for situations with solid strands I prefer the NON lever push in wagos.
Having been out on a few faults where the problem has been overheated and therefore failed Wago's, I wouldn't attempt to use them on anyhing more than a few amps. Certainly not a 6mm² 32A circuit, they aint pretty when they fail at those levels.
As suggested in my post #8My personal favoured method, is screwed terminals, or connectors, but a connector with a wide enough hole, to accommodate the two wires overlapped.
