Thanks for all the responses. I've managed to find a variable resistor with a more suitable range, 0.1 to 10 ohms, rated for 100 watts so will give that a try. Couldn't belive how hard it is to find such a thing, had to get it from the states in the end.
I am trying to encourage air flow through the garage as it suffers from damp. Crappy pre fab Hanson garage which has always let rain in around the Base, then gets into the air and makes my tools all go rusty!
£100? What was it about those that made you consider them, and what was it about the ones which are a fifth of that (or less) which made you discount them?
And if you can get fans designed to be mounted in a pane of glass, I don't know why plywood would be a problem...
