View media item 33947..View media item 33948
If you mean "Too small" based on 102 to 117mm that's the pan spigot range. The external fins, which are conical, are circa 125mm, the size the op requested.
There are no fins/gasket/seals on the Osma 4S730. How would it seal?
It should not need to. The end facing the camera will go into the OP's 125mm ID pipe. The other end will take a pan spigot of between 102 and 117mm OD.
