- Joined
- 19 May 2019
- Messages
- 2
- Reaction score
- 0
- Country
I've had boiler changed from condenser to combi so water tank removed from airing cupboard. Immersion heater switch was left in in situ but "load" cabling removed back to switch and circuit switched off at the 16A mcb.
Wanting to put a WiFi repeater in the airing cupboard I thought I'd replace the switch with a socket and reactivate the circuit.
Now the funny stuff - with the MCB pulled, there's 12VAC on the circuit (?). Tested with multimeter. Engage the MCB and 240VAC appears as expected.
Pulled the MCB to make the change. As I removed the immersion switch the RCD tripped(?)
The sockets, cooker and hob MCBs are on the same RCD.
Any ideas? Where's the 12VAC coming from?
