I have a Bain Marie at work that has a full setting on the simmerstat. When this is set to full (which is always) the appliance takes 12.8 amps continuously.
I have tried various makes and combinations of plugs and sockets, same make together, different makes together. The most frequent combination I have used is Duraplug plugs and MK sockets. Whichever is used the plugs are always burning up through heat created at the connection between the fuse and the L pin. I have tried tweaking the cradle to grip the fuse tighter but to no avail. Has anybody else experience this with high loads ?
The appliance is supplied with a fitted plug and says it is rated at 13A
