I am installing a new galley on my narrowboat. The LPG supply pipework was originally run through the old units after they were installed giving a very untidy appearance. I decided to re-route it using the service area behind the new units. On inspection it appeared to be 12mm pipe. After cutting a section of pipe I found that 12mm fittings would not fit. Measuring the removed pipe carefully it has an outside diameter of 13mm (1/2 inch).
A visit to all my local plumbers and building merchants has failed to come up with a supplier. A search of the internet has also not been successful. Does anyone know where I can get any fittings and a short length of pipe in the UK?
