Sorry just a standard house with a combi boiler. The house has a bathroom and small ensuite. Is a 15mm cold supply enough for this. The incoming supply is 25mm mdpe. Do you need to know pressure etc?
We're in process of doing much the same right now... New main into house from utilities stopcock is 32mm mdpe, this reduces to 25mm mdpe internally to internal stopcock; from there to combi is 22mm copper but this T's off to boiler, bathroom, kitchen and downstairs wc in 15mm. With a combi a smaller bore is better as long as you have good pressure and dynamic flow.
